fixing a wire terminal
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=117022
Printed Date: May 14, 2026 at 3:08 PM
Topic: fixing a wire terminal
Posted By: spmpdr
Subject: fixing a wire terminal
Date Posted: October 17, 2009 at 12:56 AM
Today I was rewiring my subs (2 re audio sr 12 's)and I must of messed up one of the terminal wire connectors because it wont tighten back down.They are the metal threaded type that you tighten with an allen wrench.If I took it to a shop should they be able to fix it ? Or does anyone have any suggestions on how to fix it?
-A vision without a plan is just a hallucination-
Posted By: i am an idiot
Date Posted: October 17, 2009 at 1:30 AM
What is stripped out?  Is it the head of the allen screw, the threads of the screw, or the threads of the piece that the screw fits into?
Posted By: spmpdr
Date Posted: October 17, 2009 at 10:52 AM
I believe its the piece that the threads fit into , I checked the threads on the allen screw and they looked fine.
Date Posted: October 17, 2009 at 8:43 PM
A drill Bit, a tap, and the next larger size screw may be in order.
Posted By: spmpdr
Date Posted: October 17, 2009 at 8:51 PM
thats what i figured thanks
