1990 t bird current issues?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=117225
Printed Date: April 06, 2026 at 11:03 PM
Topic: 1990 t bird current issues?
Posted By: snwbrdrxtreme
Subject: 1990 t bird current issues?
Date Posted: October 25, 2009 at 1:18 AM
So I'll give you my run down on what I got and my issue.
New 75 amp. Alt.
Bluetop Ultima Battery 3 months old
4 gauge Power wire running back to the amps connected first to a Rockford Fosgate 10 Farad Digital cap.
Power BD1000 Rockford Fosgate amp. running 2-10" T1 subs in a sealed box.
Phoenix Gold 4 ch. Tantrum 400.4 Diamond Audio Comp. D6 6-1/2" front and rears.
My Issue is I cant keep a constant amprage draw for my amplifier.  It runs flawless for about 1-2 mins. and then its starved for power and the bass is much less with excessive headlight dimming.  I have heard that the wiring in the older cars could be the issue, but not aware of how to start to fix it.
So my only thoughts are I either need to fix the wiring or buy a bigger Alternator.  I have never had a problem like this before owning a similar system in a Honda Civic which had a less ampreage Alt. and a much smaller Cap. Any thoughts or suggestions would be much appreciated!  Thanks
Corey
Posted By: i am an idiot
Date Posted: October 25, 2009 at 3:33 AM
Posted By: KarTuneMan
Date Posted: October 25, 2009 at 7:48 PM
understand also that your blue top optima is a deep cycle battery.... not an ideal application.
loose the cap too..
Date Posted: October 25, 2009 at 11:30 PM
Why would I loose the cap?  Just wondering?  I always thought a cap helped... But I will go thru and do the big three and look into upgrading my 4 gauge to either 2 or 0/1 gauge.  And the battery, I didnt think it was as big of a deal as it is.. I'll look for a red or yellow top and stick that batt. in my other vehicle that doesnt have a system in it.. Thanks for the info!!
Corey
Posted By: ckeeler
Date Posted: October 26, 2009 at 10:14 AM
optima blue tops are for marine applications, mostly used for trolling motors on fishing boats and such. lots of reserve capacity but not alot of CCA power.
