BEtter Audio sub amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=11725
Printed Date: May 16, 2026 at 5:53 PM
Topic: BEtter Audio sub amp
Posted By: pervitizm
Subject: BEtter Audio sub amp
Date Posted: April 01, 2003 at 7:55 PM
Has anyone ever heard of this company before, and if so have used their products. I'm looking at their mono block amp and I wanted to know if its a good buy or not here are the specs:
BEtter Audio 1600M1 Amplifier
Class D Topology
Variable Subsonic Filter (15-40Hz)
Variable Low-Pass Crossover (50-250Hz)
HP Crossover Pre-Amp Outputs
Remote Gain Control (Included)
Phase Control
Clipping, Speaker Short and Thermal Overload Protection
Dimensions: 17" x 9-1/2" x 2"
Power Output:
500x1 @ 4ohms
1000x1 @ 2 ohms
1500x1 @ 1ohm
Regular Price - $375.00 shipping included
Introductory Offer - $325.00 shipping included!
Compare this amp to the Hifonic Brutus BX1500D which one would be the better buy?
Here are the specs for the Hifonic amp:
Features
Class D Design 1 Ohm Stable
New 20th Anniversary HiFonics Heat Sink
Exponential Vari-Power Supply (EXVP)
New Ultra-Fi MOSFET Output
24 dB / Octave Variable Crossover
Subsonic Filter
Remote Bass Level Control
RMS Power: 450W x 1 @ 4 ohms
Bridged RMS Power: 900W x 1 @ 2 ohms
THD at Rated RMS Power: 0.08%
Speaker Level Inputs: No
Preamp Outputs: Yes
Built-In Crossovers: LP
Bass Boost: 0 - 18 dB
Frequency Response: 20-250 Hz
Channel Separation: n/a
Signal to Noise Ratio: 90 dB
Fuse Rating: 80 amps
------------- live & die 4 tha luv of BASS!!!!
Posted By: dragonrage
Date Posted: April 01, 2003 at 8:31 PM
One thing I'd check is the fuse rating on the unknown one. You can get amps rated high power with like 30A fuses, and you know they'll never reach that for more than a split second (internal caps) if ever ------------- 2009 Pontiac G8 in planning stage
HU: ?
Speakers: ?
Amps: ?
Posted By: djfearny2
Date Posted: April 01, 2003 at 8:37 PM
never heard of it and i used to work at a flee market with all that garbage stuff like vibe and boss.
------------- Jon
Installer/Help Technician
---coral springs florida---
Date Posted: April 01, 2003 at 10:11 PM
yeah I've checked Better audio's website and I couldn't find the fuse rate on it, but I've been hearing good things about this amp on other forums like carsound and caraudio. However, I tend to follow the words and opinions of people from this forum more than any other car audio forum on the net, that way I posted this question about this company here. I just hope that someone here has had experience with Better Audio and could tell me what they thought about their products.
Date Posted: April 03, 2003 at 12:33 PM
Okay since know one here knows about Better Audio, what about this rack amp from Lanzar
Model D3000M 3000 Watt Mono Block MOSEFT Digital Power Amplifier
Mono Block Subwoofer Amplifier
1 Ohm Stable
MOSEFT Power Supply
PWM (Pulse-Width Modulated) System
Glass Epoxy PCB
Custom Terminal Block for Speaker Connections
Thermal, Overload & Short Protection
Remote Bass Control
Variable Subsonic Filter (15Hz-60Hz,24dB/Octave)
Variable Low Pass Filter (50Hz-250Hz,24dB/Octave)
Variable Bass Boost (0~18dB)
Input Impedance: 10k Ohms
Rack Mount
Dimensions: 13.8” (W) x 2.3” (H) x 16.7” (L)
I found it on ikesound.com for $315, is this amp worth my money?
