re audio se12-d4 or 12" alpine type-r?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=117479
Printed Date: May 04, 2026 at 8:04 PM
Topic: re audio se12-d4 or 12" alpine type-r?
Posted By: imupabove
Subject: re audio se12-d4 or 12" alpine type-r?
Date Posted: November 05, 2009 at 1:02 AM
Amp: Kicker 750.1 (06 model)
which sub will perform better/louder:
RE Audio SE Series SE12-D4 or 12" Alpine Type-R.
Posted By: daniel gt1
Date Posted: November 05, 2009 at 1:10 PM
I think the box design will determine that..re audio subs can generate otimimum and compact bass..alpine subs sounds clean when its in a slot ported box tunedto about 33 or 34 herts ....correct me if I'm wrong guyz
Posted By: j.reed
Date Posted: November 05, 2009 at 1:31 PM
RE FTW. More power handling and IMO just a better sub all the way around. -------------
Posted By: mrarff
Date Posted: November 05, 2009 at 1:54 PM
An Alpine R-3 dualVC 4 ohm in a ported box is very hard to beat. Mine is powered by a kenwood 9103 wired to 2 ohm, and it works very well. But keep in mind, I'm not looking for "loudness", I'm lookin' for quality bass reproduction at moderately loud levels. ( in an 08 Chevy HHR) However , my 20 yr old "deaf" (not deff) son has the same in a sealed box. (same amp, same wiring in an 08 Chevy Cobalt 4dr) and he says that his is "off da hook" (great too). So go figure.... BTW.. they really will handle more than 500 watts rms!
------------- "That'll get ya 10 in Leavenworth,11 in Twelveworth, or 5 & 10 in Woolworth". Groucho Marx
Posted By: spmpdr
Date Posted: November 05, 2009 at 3:31 PM
Ive had a 2 12" type Rs and now run re audio se 12" in a sealed enlcsure .Ran them both off the same 1000 watt memphis monoblock and the RE are way better than the type r for sq and spl i.m.o
------------- -A vision without a plan is just a hallucination-
Posted By: boogeyman
Date Posted: November 05, 2009 at 4:51 PM
I'd go with the RE
Posted By: nodiggie
Date Posted: November 06, 2009 at 12:22 AM
After MUCH research and consideration of just about every mfg. out there I decided to go RE. Single MX15D2 powered by BXI2610 (for now)lol. My box will be completed this next week and everyone I've spoken with that competes says it's going to be a monster. We'll see.
------------- Still learning
Kraco
Posted By: metaljoey
Date Posted: November 07, 2009 at 10:23 AM
i have the same amp. its hard to beat for the price! a tad over rated on the power tho. prob more like 1800-2000 RMS @ 1 ohm. you get the proper box built for that sub, she'll pound!!
------------- Before you see the light, you must die!!
Date Posted: November 07, 2009 at 12:49 PM
you think that RE SE12-D4 will pound in this box?
width: 30 inches
height: 14 1/4
depth:17 1/2
port measurements
height: 12 5/8
width: 2 7/8
1.5 mdf thick
Date Posted: November 07, 2009 at 5:47 PM
hit the Calculators, Charts, Diagrams @ the top of the Paige. it will help you to find out the specs of your box! you will also need to know the port length to find out the Hz of the box. cheek it out its a good time!!!
