gmos 01
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=118311
Printed Date: March 31, 2026 at 12:37 AM
Topic: gmos 01
Posted By: 08canyon
Subject: gmos 01
Date Posted: December 07, 2009 at 2:09 PM
So i searched for information on the GMOS-01, I don't think I found what I was looking for. I have a 2008 GMC Canyon, OnStar/Non-Bose. I am wanting to install a double din JVC KW-XG700 head unit. I plan on running separate sub/high-mid amps. Am I to understand that the GMOS-01 module uses the front left speaker for it's chimes and such? If so, what's the point of using the module if I am installing after market door speakers running off an amplifier?
Am I missing something here?
Many thanks,
-josh
Posted By: i am an idiot
Date Posted: December 07, 2009 at 2:24 PM
The chime originates from the factory radio, or the OS1 if you remove the radio. Without the module, you will lose the chime and also the On-Star.
Posted By: soundnsecurity
Date Posted: December 07, 2009 at 2:43 PM
i would buy a small speaker to hook up to the gmos-01 and hide that speaker away somewhere under the dash that way you can still have your onstar and still run the amp the normal way
