finding a good amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=119247
Printed Date: April 18, 2026 at 2:01 AM
Topic: finding a good amp
Posted By: mastermindz
Subject: finding a good amp
Date Posted: January 11, 2010 at 1:31 AM
I'm lookin for a new amp for my vocals, i have a Pioneer TS-D1720C in front with two pair of Pioneer TS-A6993R, they total 440 rms and 2360 max, i want an amp that can push these speakers to their max, any suggestions? thanks
Posted By: haemphyst
Date Posted: January 11, 2010 at 7:26 PM
First: Ummm.... 2300 watts? For a 6by? BS! I have no idea WHERE that number came from, it's completely made up.
Those are 440 watts peak. 2-80 watts. Anything in that range will be fine.
Second: Why do you think you have to push them to their max? No need, and no benefit beyond 50 watts (real world watts, not Audiobahn watts...) or so.
Date Posted: January 12, 2010 at 2:35 AM
So what would be the best way to wire these 6 speakers to a 4 channel amp?
Mastermindz
Date Posted: January 12, 2010 at 10:47 AM
Parallel the fronts for a 2-ohm load, and run the rears as-is. If you only want loud, you're gonna be golden, but for SQ, you're going to start fresh, with new speakers - and NOT 6X9s - and only run one set up front.
Date Posted: January 12, 2010 at 4:29 PM
I'm sorry, i think i described my system wrong, i have the Pioneer TS-D1720C in front with a total of 120 watts RMS and 520 watts max for the front, and then in the rear i have two pair of Pioneer TS-A6993R with a total of 320 watts RMS and 1840 watts max, for a total of 440 watts RMS, and 2360 watts max for all speakers, so what would your suggestions be for wiring and amp? thanks
Mastermindz
