strange issue with my subwoofer
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=121027
Printed Date: April 18, 2026 at 4:51 PM
Topic: strange issue with my subwoofer
Posted By: p71rida
Subject: strange issue with my subwoofer
Date Posted: March 28, 2010 at 5:53 PM
When I turn down the headunit volume to almost nothing at "1" my subwoofer is still pounding at whatever level I have the gain set at. I have to turn the headunit vol to "0" in order for the subwoofer to go out or I have to set the gain all the way to "0" on my amp but if I do that than I guess there's really no point of even having subwoofers in my trunk. I thought I was having a grounding issue so I changed the grounds to couple different spot but its doing the same exact thing. I just have a basic setup.. running rca sub out from my headunit to my amp. I also want to point out that my headunit does not have a subwoofer control. Can anyone please tell me what might be causing this?
2003 FORD CROWN VICTORIA P71 INTERCEPTOR
Posted By: ncreaper247
Date Posted: March 30, 2010 at 4:29 PM
it sounds like it may be a problem with your head unit. I would suggest returning the one you have for a new one (if possible) or maybe spending some money to buy a little more expensive headunit with a sub-output control.
Posted By: i am an idiot
Date Posted: March 30, 2010 at 7:19 PM
