a8002t amp/ rf 10 inch sub wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=121035
Printed Date: April 18, 2026 at 7:18 PM
Topic: a8002t amp/ rf 10 inch sub wiring
Posted By: willy1226
Subject: a8002t amp/ rf 10 inch sub wiring
Date Posted: March 29, 2010 at 12:06 AM
I have:
   Audiobahn A8002T amplifier
   One 10 inch Rockford Fosgate P3D410 sub
RMS Power Output:
    * 200 watts x 2 chan. @ 4 ohms
    * 400 watts x 2 chan. @ 2 ohms
    * 800 watts x 1 chan. @ 4 ohms Bridged
Max Power Output: 1600 watts @ 2 ohms
All A8002T Specs
Subwoofer: 10 inch DVC 800 Watts max, 400 RMS @4 ohms.
All P3D410 Specs
So, I have one 10 inch RF and one Audiobahn A8002T amp. I would greatly appreciate some guidance on how to wire this up. I was thinking of wiring the DVC in parallel @2 ohms on one channel since the amp will probably not be stable @2 ohms bridged and the power would probably kill my sub. How would you guys suggest to wire this up? Thanks in advance.
Date Posted: March 29, 2010 at 12:16 AM
Apparently I can't insert huge links. I apologize. Here is the link for the amp specs.
https://www......com/item_73_Audiobahn+A8002T.html
Posted By: j.reed
Date Posted: March 29, 2010 at 1:07 AM
Your linking to off site sales/forbidden links thats why the links for the amp are not working.
one channel at 2ohm is going to give you the same power as 8ohm bridged. Wire it at 8ohm bridged. You will have full input/output signal that way.
posted_image
posted_image
Date Posted: March 29, 2010 at 7:17 AM
Thank you for your input. 8 ohms won't be too much resistance for my amp? or does it just reduce the power? I don't want to damage it. I hope this amp will be able to have enough power @8 ohms.
Posted By: j.reed
Date Posted: March 29, 2010 at 1:28 PM
It will be easier on the amp at 8ohm bridged than it would be at 4ohm. Simple ohms law. Its not going to hurt anything. Infact the amp will run cooler and easier at that ohm load, extending life apposed to running it at its minimum independence. The amp will actually be seeing a 4ohm load across each channel. You will see about 400 watts X 1 @ 8ohm.
posted_image
Date Posted: March 29, 2010 at 3:20 PM
Thank you very much. I'm wiring it all up today, so we shall see how it sounds.
Date Posted: March 29, 2010 at 8:29 PM
I got it all wired up and it sounds great! I wired it at 8 ohms bridged like you said and it seems to be the way to go. Thanks again!
