wiring 24 woofers to 1 amp.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=121139
Printed Date: March 22, 2026 at 6:13 AM
Topic: wiring 24 woofers to 1 amp.
Posted By: midnightfocus
Subject: wiring 24 woofers to 1 amp.
Date Posted: April 03, 2010 at 8:28 AM
Im trying to figure out a way to wire 24 svc woofers to 1 amp, i have 2 amps i can wire them to, a two channel or a mono-block, the mono-block is stable at 1 ohm, has ran at .5 ohms fine. The two channel amp is 2 ohm stable per channel or 4 ohm stable bridged, is there anyway i can wire this down to have all 24 woofers on Either amp? they are not designed for bass but im bored and doing a project for school and figured i would mess around with these, they came pretty cheap at 69cent a pair, so im not worried about if i blow them. i think there like 5 rms per, the two channel amp is 75 rms at 4 ohms per channel, 110 rms at 2 ohms per channel. the mono block is 2400rms at 1 ohms, 1,600 x 1 RMS at 2 ohms, and 800 x 1 RMS at 4 ohms... im not worried about power, i can always turn down the amp gain/radio settings to match the speakers, no matter how small...
Date Posted: April 03, 2010 at 8:31 AM
Note* they are 4ohm SVC woofers.
Posted By: KPierson
Date Posted: April 03, 2010 at 9:41 AM
Start off by making 12 pairs of series woofers giving you 12 8ohm sets. Then parallel 6 pairs giving you 6 sets of 4ohm speaker systems. Wire 3 pairs in series giving you 3 8ohm systems. Wire each of those to the monoblock amp for a 2.66 ohm load. ------------- Kevin Pierson
Posted By: KPierson
Date Posted: April 03, 2010 at 9:53 AM
Posted By: KPierson
Date Posted: April 03, 2010 at 9:54 AM
The "green" lines turned out more black - sorry about that.
Posted By: 4g15
Date Posted: April 07, 2010 at 4:26 PM
how 2 notify power output watt and ohm from my amplifier???
