my stereo cuts off at high volume
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=121425
Printed Date: April 18, 2026 at 1:53 PM
Topic: my stereo cuts off at high volume
Posted By: tylersee
Subject: my stereo cuts off at high volume
Date Posted: April 19, 2010 at 8:54 PM
i have a kenwood mp342u head unit and visonik amp rms 300 and pioneer champion series subwoofer that rms 350. here is the problem when i turn it up to about 30 out of 35 my head unit will shut off then turn back on it will keep doing this if i keep it turned up. What might the problem be? thanks for the help
Posted By: i am an idiot
Date Posted: April 19, 2010 at 9:13 PM
If the headunit is turning all the way off, lights and all. The radio is losing voltage on the Yellow wire. Where do you have the amplifier's power wire connected?
Posted By: tylersee
Date Posted: April 20, 2010 at 6:57 AM
if you are talking about the remote turn on i got it hooked up to the motor attena wire
Date Posted: April 20, 2010 at 7:30 AM
The power wire of your amp, the large wire, where is it connected?
Posted By: tylersee
Date Posted: April 20, 2010 at 8:25 AM
it is connected to my battery
Posted By: DYohn
Date Posted: April 20, 2010 at 12:31 PM
Is the head unit turing off completely or is it just cutting out? Are you powering door speakers off the head unit? ------------- Support the12volt.com
Posted By: tylersee
Date Posted: April 20, 2010 at 2:20 PM
it shuts off completly and then turns back on and yes the door speakers are run off the head unit
Posted By: DYohn
Date Posted: April 20, 2010 at 5:12 PM
Then it sounds like you have a short somewhere. Disconnect all your speakers and see if the head unit still does the same thing. ------------- Support the12volt.com
Date Posted: April 20, 2010 at 7:17 PM
Instead of disconnecting the speakers, balance left and listen to it. Then balance right, listen to it again. If it cuts off with only one or the other channel playing, there is probably a problem with the speakers or the wiring of the channel that is making it cut off. If both channels play fine by themself, chances are you have a voltage drop problem on the yellow wire of your radio.
Posted By: tylersee
Date Posted: April 21, 2010 at 8:53 AM
alright thank you
Posted By: tylersee
Date Posted: May 01, 2010 at 11:11 AM
i have an visionik amp that has a built in fan it is popping both of the fuses after it runs for a minute it doesn't pop them as i put them in. i have looked at most of the wiring going to the amp. it recommends two 20 amp fuses should i put like two 30amp fuses and see what happens
Posted By: tylersee
Date Posted: May 01, 2010 at 12:05 PM
i have a 600 watt visionik amp yesterday i was driving to my grandmas and i noticed that my sub stoped hitting so i stoped to see what was the problem it blew both fuses so i put teo 20 amp fuses back in it and it lasted for a minute or so and stoped so i just checked it and tryed more fuses same thing happens i have checked my sub wires they are fine. what is causing this
Posted By: icearrow6
Date Posted: May 01, 2010 at 1:36 PM
What size fuse is on the amp itself?
It might be that 20A fuse may be too small.
Posted By: tylersee
Date Posted: May 01, 2010 at 2:01 PM
it has teo 20amp fuses
