subwoofer making constant popping sound.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=121477
Printed Date: May 16, 2026 at 4:22 AM
Topic: subwoofer making constant popping sound.
Posted By: jlcub11
Subject: subwoofer making constant popping sound.
Date Posted: April 23, 2010 at 7:12 PM
I hooked my sub up to my amp last night. Sub is producing a constant poping sound while the amp is on whether the volume is up or down. Equipment installed includes the following:
- Factory installed head unit
- JL Cleansweep
- JL MHD900/5 - 5 channel amp
- JL Stealthbox
- JL C2-570x front & rear speakers
- 16 gauge speaker wire (Factory harness to Cleansweep then from amp back to the new speakers)
- 4 gauge power cable (From battery to amp. Negative connect to truck frame. Metal was sanded before making connections)
- Monster rca cables (From cleansweep to amp)
Cleansweep was calibrated after install. Front & Rear speakers output clean & clear sound at all volumes.
Amp is set on 4-channel (can be set to 2 or 6) since there are only 4 channels coming out of the Cleansweep.
My thought is that I seeing possibly a voltage drop but I really have the clue and would appreciate any thoughts. Like I said the amp seems to work great with the front and rear but receiving a popping sound (pop pop pop) from the sub when connected.
Posted By: jlcub11
Date Posted: April 23, 2010 at 7:15 PM
One last thing.. I did connect the sub into the rear output of the amp to check to see if it was a bad sub and I get clean sound out of it.
