cd player in 03 cavalier
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=121557
Printed Date: May 16, 2026 at 6:38 AM
Topic: cd player in 03 cavalier
Posted By: doug55
Subject: cd player in 03 cavalier
Date Posted: April 27, 2010 at 1:58 PM
Ok I attempted to install a dual cd player in my friends 2003 cavalier I have the gm 2000 interface wiring harness. Matched up all wiring by the colors only wiring left was blue amp wire and an orange wire in the harness the chimes work but cd player will not turn on. Anyone know what might be the problem ?
Posted By: KPierson
Date Posted: April 27, 2010 at 2:42 PM
Check to make sure you have ground on the black wire at the radio, constant 12vdc on the yellow wire at the radio, and switched power at the red wire at the radio.  Measure the voltage AT the radio to make sure the radio is getting the voltage.
Kevin Pierson
Posted By: paidnfull
Date Posted: April 27, 2010 at 2:43 PM
Don't know that particular harness of the top of my head.  But not all the harnesses for those vehicles have an accessory wire.  May need to run your own, either to the ignition or fuse box.  You checked all your fuses?  Checked voltage on the red and yellow wires?
Posted By: doug55
Date Posted: April 27, 2010 at 4:15 PM
I just tying the cd players ground wire to the cars same on becaUse the stock one is working fine when I hooked it back up maybe it's the harnessed I dont know
