subwoofer enclosures, 2004 ford ba
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=121633
Printed Date: March 31, 2026 at 6:24 PM
Topic: subwoofer enclosures, 2004 ford ba
Posted By: xrcecere
Subject: subwoofer enclosures, 2004 ford ba
Date Posted: May 02, 2010 at 8:06 AM
I am installing 2 rockford fosgate t1's in my 2004 ford ba will they sound good inverted?
Posted By: ianarian
Date Posted: May 02, 2010 at 11:30 AM
Recent poles indicated that a majority of Americans preferred the 04' Chevy with inverted P1's.... but it's really anybody's ball game.
This is what I do for FUN!
Posted By: j.reed
Date Posted: May 02, 2010 at 8:46 PM
You will notice NO difference. The only difference other than the look would be the motor and basket not taking up space in the enclosure. Making the enclosure what?, about 0.2cu.ft difference.
posted_image
Posted By: xrcecere
Date Posted: May 03, 2010 at 1:34 AM
awesome, ive heard mixed things about it, any suggestions on the box, i have heard from one guy to make the box as big as possible to fit into the space its going..
Posted By: xrcecere
Date Posted: May 03, 2010 at 1:40 AM
And how will two 12" t1's go against two 12" terminators?
Posted By: j.reed
Date Posted: May 03, 2010 at 1:33 PM
You will want about 2.25 NET per sub. Plus port volume and any bracing.
Fosgate T2-T1 Recommended enclosure
posted_image
Posted By: haemphyst
Date Posted: May 04, 2010 at 9:19 AM
Not likley... But they won't sound good NOT inverted, either! posted_image
Posted By: xrcecere
Date Posted: May 04, 2010 at 2:36 PM
allright buddy, thanx for your opinion, ive had them in installed in a normal box, they sound tough.
Posted By: xrcecere
Date Posted: May 04, 2010 at 2:37 PM
Should i port the sub box if im having my subs sitting inverted?
Posted By: j.reed
Date Posted: May 04, 2010 at 3:11 PM
inverting or normal load will not make a difference whether you should go sealed or ported. You desired sound and available space is what will determine sealed or ported.
Here is a link to the Rockford Fosgate Box recomendations This will give you the sealed and ported recommendations for your sub.
posted_image
