sub box, 2000 chevy extended cab
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=121800
Printed Date: April 18, 2026 at 5:50 AM
Topic: sub box, 2000 chevy extended cab
Posted By: tj546
Subject: sub box, 2000 chevy extended cab
Date Posted: May 12, 2010 at 11:07 AM
  I have 4   12" earthquake LS  subs   going in my 2000 chevy extended cab truck.  the box is 38w 26t 18.5d=8.79qf   the port is 9.5tall 12 wide and 13.67 long. the box dosent  sound good at all loud as hell in my shop but sounds like hell in my truck. i have more than enough power for these subs just could use some help with this. oh the subs are facing up vented out the front of the box.
Posted By: tj546
Date Posted: May 12, 2010 at 11:18 AM
the subs are older but new ive had them for a while. the vent tuning is 43 hertz
Posted By: tj546
Date Posted: May 12, 2010 at 12:02 PM
i need helpwith this please!!!!
Posted By: eric21
Date Posted: May 17, 2010 at 10:12 AM
I have a crew cab with 4 12" alpin type r's and had the exact same problem - it sounded like garbage even with 3000 watts. I had a center port with the
posted_image
subs around it like in the picture. It sounded best pointed up but still not very good.
My next box I built had the 4 12's along the bottom with 2 areo ports like the picture below
posted_image
This box sounded much better than the last and sounded best pointed foward. The size was about 9cu.ft. net. I later shrunk it down to 7cu.ft. net, it lost some low end but picked up the high bass alot better.
I think what I would do if I was you is to build a box with the subs foward and one long port along the back top of the box. It may not follow the 7 to 1 rule with port dimensions but i've seen and heard it before and it sounded good. I would divide the box into 2 chambers, so 2 ports along the top back of the box.
