alpine cda 7930 to ipod
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=122405
Printed Date: April 25, 2026 at 3:51 AM
Topic: alpine cda 7930 to ipod
Posted By: boghog1
Subject: alpine cda 7930 to ipod
Date Posted: June 23, 2010 at 9:08 PM
I have an older alpine CDA 7930 I am trying to hook up to an iPod I have added Alpine KCA-121B but the tuner won't give me the source for either changer or auxilary I have read through the manual for the CDA 7832 (should be the same since it is the same but with internal amplifier) Does anyone have any insights they would be willing to share? thanks in advance
Posted By: boghog1
Date Posted: June 23, 2010 at 9:09 PM
if you need it this is in a 98 Ford ranger with a MRV4004 Amplifier powering the factory speakers for now
Posted By: i am an idiot
Date Posted: June 23, 2010 at 10:19 PM
I do not think that deck supports Aux input via the KCA-121B. You have to enable Aux in via the function menu.
Posted By: boghog1
Date Posted: June 24, 2010 at 5:31 AM
I can't seem to find a way to turn on the aux funnction, does Alpine have a tech support where you can ask questions, unfortunately the deck is so old it is tough to get information on it.
Date Posted: June 24, 2010 at 8:43 PM
Alpine does have a dealer support line, I called them 3 times today, each time they said it would be a 15 minute wait. I will try to remember to call tomorrow too. I am about 99% sure that your radio does not support the AUX in via the 121B.
Posted By: boghog1
Date Posted: June 25, 2010 at 7:03 AM
Thank you, I apprecite it. I had my alpine certification back on the late 90's but got out of the 12 volt industry in 99 to work at a desk job I wish I had kept my stuff from back then
Posted By: boghog1
Date Posted: March 16, 2011 at 1:22 PM
Well the answer to this question is you need to turn the mute function off and ground the pink black interrupt wire to make it work,
To turn off mute press and hold the power button for three seconds then press the preset button 2 to turn the mute off. I plan on wiring up a toggle switch for grounding the wire when I want to listen Hope this helps someone else in the future
