97 eclipse remote starter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=122410
Printed Date: April 25, 2026 at 5:15 AM
Topic: 97 eclipse remote starter
Posted By: mitsu79
Subject: 97 eclipse remote starter
Date Posted: June 24, 2010 at 10:34 AM
hi guy, here the situation, 97 eclipse..the car only start with the remote starter..wont start or crank with the key?? can it be the ignition harness?? thanks
------------- pp
Posted By: 91stt
Date Posted: June 24, 2010 at 10:56 AM
Do you have an aftermarket security system installed?
Was the remote start recently installed?
Possible cause can be a bad ignition switch or an open in the starter wire.
If there is a starter interrupt/anti-grind relay installed, it may have a bad connection or the relay is has gone bad.
------------- This information is provided only as a reference.
All circuits should be verified with a digital multi-meter prior to making any connections.
Posted By: mitsu79
Date Posted: June 24, 2010 at 12:29 PM
the avital 4103 remote starter..it's in the car for 5 months...everything was fine until last week..the car still start up and drive but with the remote starter only..
------------- pp
Posted By: mitsu79
Date Posted: June 24, 2010 at 12:32 PM
i took the starter out and the car won't start either..the ac is on, radio is on. light on the cluster is on..but won't crank...it can't be the starter on the car because it start with the remote.thanks
------------- pp
Posted By: 91stt
Date Posted: June 24, 2010 at 12:54 PM
Did you install it yourself or had a shop do it?
If a shop did it, have them troubleshoot it.
With the information thus far, I still suspect an open in the starter wire.
Posted By: 91stt
Date Posted: June 24, 2010 at 1:45 PM
to clarify, I am referring to the start wire from the ignition switch
Posted By: mitsu79
Date Posted: June 24, 2010 at 2:23 PM
the ign harness rite?
------------- pp
Posted By: 91stt
Date Posted: June 24, 2010 at 4:06 PM
Did you install the remote start on your own?
How did you tap into the start wire in the ignition harness?
Did you cut the wire?
