4 ohms bridged?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123737
Printed Date: April 01, 2026 at 10:32 AM
Topic: 4 ohms bridged?
Posted By: paulcummings32
Subject: 4 ohms bridged?
Date Posted: October 01, 2010 at 3:12 PM
i have a dual 4 ohm VC woofer and an amp that will provide 560 RMS at 4 ohms bridged.   being that i can only wire my sub to get 2 ohms or 8 ohms can i still bridge it and get 560 RMS at 4 ohms bridged?
Boosh
Posted By: icearrow6
Date Posted: October 01, 2010 at 4:00 PM
simply no,
Like you said the amp will see either 2 ohms (parallel) or 8 ohms (series).
Since overloading the amp at 2 ohms is not recommended, I suggest you run it at 8ohms bridge.
This way the amp will see the same as 4ohms per channel.
Date Posted: October 01, 2010 at 4:06 PM
what kind of rms will that get me?
Boosh
Posted By: afdanw
Date Posted: October 01, 2010 at 4:13 PM
bridgeing into 8 ohm will get you about half of what it would be bridged into 4.  That being said i agree with icearrow6.  it is batter to under power, than to over drive the amp by bridging into 2 ohm, and burning it up.
If your cousin is such a good installer, and he will install anything for a 6 pack; why are you talking to me?
Date Posted: October 01, 2010 at 4:20 PM
thank you both very much!
Boosh
