metra wire harness for 2009 honda accord
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123907
Printed Date: April 02, 2026 at 6:46 AM
Topic: metra wire harness for 2009 honda accord
Posted By: threedd97
Subject: metra wire harness for 2009 honda accord
Date Posted: October 12, 2010 at 10:28 PM
I have this https://metradealer.com/api/vfg/view-product/id/70-1730 to integrate my factory amp into my Pioneer avh-p4200. I have no clue what those RCA's are for or what they connect into. Anybody know? If I can't figure it out I have a normal harness for my car to use.
Posted By: mrm1776
Date Posted: October 12, 2010 at 10:35 PM
You plug the RCAs into the new aftermarket headunit and you don't attach the speaker leads coming off of the headunit's harness. Just tape them up.
MECP Basic Installation Tech
Certification ID: CEA195600
Pioneer AVIC-X920BT
Polk Audio DXi 6500 - front
Rockford Fosgate Power T1693 - rear
Alpine MRP-F300
Alpine MRP-M500
Alpine SWR-1242D
Posted By: mrm1776
White - Left Front
Gray - Right Front
Green - Left Rear
Violet - Right Rear
Pioneer AVIC-X920BT
Alpine MRP-F300
Alpine MRP-M500
Alpine SWR-1242D
Date Posted: October 12, 2010 at 10:54 PM
What does this connect to? I assume it's for the little 8" driver (the 7th speaker).posted_image
Posted By: mrm1776
Date Posted: October 13, 2010 at 9:24 AM
Yep... that would most likely be for the factory sub in there. Do you not have a car side harness that it can plug into? And then of course it would plug into the aftermarket radio into one of the sub inputs. I'd advise getting a Y-adapter RCA so that you can hit both Left and Right channels.
Pioneer AVIC-X920BT
Alpine MRP-F300
Alpine MRP-M500
Alpine SWR-1242D
Date Posted: October 13, 2010 at 2:25 PM
Yeah I found the factory harness to plug it into and put it into the white sub output on the head unit. Its just temporary until I replace my blown 12" though so I won't concern myself with the y adapter. Thanks for all the help guys. Appreciate it!
It's all hooked up and running properly. Only thing is the iPod crackle sometimes on the Avh-p4200, but nothing else crackles.
Posted By: mrm1776
Date Posted: October 14, 2010 at 7:43 AM
Are you using the pioneer cable? The one with the USB and A/V input?
Pioneer AVIC-X920BT
Alpine MRP-F300
Alpine MRP-M500
Alpine SWR-1242D
