f250 car stereo problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=124270
Printed Date: May 16, 2026 at 12:36 AM
Topic: f250 car stereo problem
Posted By: jinx6570
Subject: f250 car stereo problem
Date Posted: November 03, 2010 at 6:42 PM
I need some help. I was installing an aftermarket CD player in my 2005 Ford F250 when the 12 volt ignition (red) wire touched some metal and sparked. The fuse at the the fuse panel is still good but is not getting power to it with the key on and I can't figure out why. Any help is greatly appreciated.
Posted By: Ween
Date Posted: November 03, 2010 at 8:30 PM
did you check both fuses for the radio, 11 and 42?
mark
Posted By: 66sportfury
Date Posted: November 06, 2010 at 6:46 AM
jinx6570 wrote:
I need some help. the 12 volt ignition (red) wire touched some metal and sparked.  Any help is greatly appreciated.
this is why they want you to disconnect the battery, could have been worse than a fuse or a breaker,
check the box under the hood also, or a fusible link in line of the power wire,
ac delco am radio and sparkomatic 40 watt sound exploder
Posted By: roadshop570
Date Posted: November 07, 2010 at 9:07 PM
Double check both fuse panels with a voltmeter and check fuses labeled radio acc, etc, also fuses that connected w cigarette lighter, dome light,etc, please check both sides of the fuse.
Chadillac
