ground question?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=12442
Printed Date: May 09, 2026 at 1:45 PM
Topic: ground question?
Posted By: equalizir
Subject: ground question?
Date Posted: April 19, 2003 at 9:32 PM
hi guys,just wanted to know in a three amp setup do i need to have more than one ground point?
Posted By: Cletis
Date Posted: April 19, 2003 at 10:16 PM
No, just make sure that you pick a good place to ground them, and make sure that it is a secure connection into bare metal.  I think it is better to use the same point, that way you reduce the risks of ground loops.
Posted By: wrencher_25
Date Posted: April 19, 2003 at 10:20 PM
For sure, just make sure you're ground wires are the same gauge as your power wires, a lot of ppl neglegt that.
Andrew Weitzel
MECP First Class Installer
Posted By: Big Purds
Date Posted: April 21, 2003 at 6:45 AM
I typically use a wire one size bigger for my grounds...just to be sure there will be no grounding problems...
