opinions on JBL 600.1
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=12473
Printed Date: March 28, 2026 at 10:20 PM
Topic: opinions on JBL 600.1
Posted By: 942drYukon
Subject: opinions on JBL 600.1
Date Posted: April 20, 2003 at 7:33 PM
I'm planning on running 2 12w3v2's or 2 12" idq v3's, would a JBL 600.1 be a good match for these subs?  If I run the JL's at 2Ohms it would be 300watts per sub which is the RMS, the idq's have a 250rms, but it should be fine at 300.
Opinions on the JBL 600.1 quality wise?  Will it have bad sound quality, or will be be just fine?
Posted By: esmith69
Date Posted: April 20, 2003 at 8:45 PM
These amps are MADE for pushing subs and they really do pack a punch.  I like the fact that they can handle really low ohm loads (1 ohm manufacturer recommended, but I've seen them run at lower loads);  it makes wiring up subs a whole lot easier.  From what I have seen they are pretty tough and will last you a good while.
Of course the usual advice applies:  don't push it past its designed limits, give it ample room to breathe, and hook it all up correctly.
Posted By: Big Purds
Date Posted: April 21, 2003 at 6:36 AM
the 600.1 is a great amp, especially since it does its rated power at both 1 and 2 ohm loads...
bang for buck, you cannot beat the JBL PowerValve amps...the 1200.1 and the 600.1 are really true performers with a very small price tag...they are a very reliable amp that wont disappoint...
Posted By: Blazermedic
Date Posted: April 21, 2003 at 11:20 AM
I've never seen a 600.1 pushed real hard, but I have seen a 1200.1 running within an inch of it's life at 1 ohm like a champ. I think they are reliable amps with alot of flexibility. For the price it's tough to beat.
