reverse wire on head unit in chevy 2500hd
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125951
Printed Date: April 23, 2026 at 5:54 PM
Topic: reverse wire on head unit in chevy 2500hd
Posted By: silverbullet555
Subject: reverse wire on head unit in chevy 2500hd
Date Posted: January 31, 2011 at 11:10 AM
I installed a Pioneer AVH-P4200DVD into my truck, a 2007 Chevy 2500HD Classic and am installing a backup camera. The head unit needs to connect into a reverse signal in order to know when the truck is in reverse. I was going to tap into the reverse output off of the BCM.
Is that ok or am I going to be putting too much load on the BCM.
Reverse Light  lt. green  +  BCM, black plug, pin F
Also, can I use that same positive source to power the back up camera? If not, my thought is to use that trigger to trigger a relay and then run the backup camera and the reverse input for the deck off the relay.
James
Posted By: i am an idiot
Date Posted: January 31, 2011 at 9:57 PM
Powering the camera off of the reverse lamp is the safest bet.  If you know for output wire at the BCM is the actual wire that provides the 3 or so amps of current to the lamps, that will be fine.
