2005 silverado, retained accessory power
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=126940
Printed Date: May 15, 2026 at 10:42 PM
Topic: 2005 silverado, retained accessory power
Posted By: 87gple
Subject: 2005 silverado, retained accessory power
Date Posted: April 12, 2011 at 7:16 PM
I searched but couldn't find an answer. Is there a way to hook up an aftermarket stereo that doesn't turn off when the key is turned off? I want my aftermarket stereo to "behave" like a stock stereo. Stay on when key turned off, shuts off after 10 min or so, or shuts off when the door is opened.
On my 2006 Cobalt I was able to hook up my stereo so that it "behaves" like stock. Can it be done in my Silverado?
Posted By: i am an idiot
Date Posted: April 12, 2011 at 9:07 PM
Posted By: blanx218
You can get a Metra GMRC-01 online for about $46. It will give you the RAP(Retained Accessory Power), an ignition turn on lead, and also retain the door chime.
Posted By: 87gple
Date Posted: April 15, 2011 at 2:14 AM
Yeah I got the GMRC-01 and installed it. Works like a charm! Thanks
I though I could hook it up like my Cobalt stereo. In the Cobalt I put a fused lead in an empty slot in the fuse panel and it works like stock. I couldn't find any slots or fuses like that in the Silverado.
Thanks again!
