toggle switch
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=12699
Printed Date: May 11, 2026 at 1:42 AM
Topic: toggle switch
Posted By: thriller
Subject: toggle switch
Date Posted: April 24, 2003 at 6:19 PM
hi guys,
i want to put a toggle switch in my car so i can turn my amp on anf off when ever i please.how do i do this.
thanks
Posted By: Velocity Motors
Date Posted: April 24, 2003 at 6:47 PM
Install a two pin toggle switch inline of the remote turn on lead of the stereo. This will allow you to turn on and off the remote turn on lead thus turning on / off the amplifier. posted_image
Posted By: Blazermedic
Date Posted: April 25, 2003 at 12:42 AM
Hey Jeff,
     Along the same topic line, if I use a glowing toggle switch, it is okay to use the remote turn on wire as the switched power source?
Cary
Posted By: wvsquirrel
Date Posted: April 25, 2003 at 2:22 AM
If you're using a glowing toggle switch in the same manner (remote lead on/off switch), then yes it's ok. I've done it before. If I remember right, the only difference is an extra terminal on the back of the switch for ground. If you want to be safe, you can always still test the load at the amp when you turn on the switch and make sure it's still receiving the required voltage. But like I've said, I've done this before with no problems.
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
Date Posted: April 25, 2003 at 3:05 AM
Hey squirrel,
      I didn't think it would cause a problem, as I vaguely remember doing that a few years ago. I just wanted to check my logic with someone else because my bright ideas always come after 45 hours of no sleep. Thanks buddy!!
Cary
