monster rca cables?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=127284
Printed Date: May 16, 2026 at 2:33 AM
Topic: monster rca cables?
Posted By: maxxx
Subject: monster rca cables?
Date Posted: May 10, 2011 at 9:47 AM
Hello, curious if anyone has had a poor experience with Monster "Ultra" car audio cables? I'm looking for decent twisted pair construction with a well-built, sturdy head termination, and these seem to fit the bill. They're cheap, so unless anyone objects, I'm going for 'em...
destination moon
Posted By: awdeclipse
Date Posted: May 10, 2011 at 12:03 PM
Monster and cheap in the same sentence? This is a first for me.
Posted By: oldspark
Date Posted: May 10, 2011 at 5:17 PM
And for RCA? Quad shielding I can imagine, but monster as in large gauge?
Posted By: roadshop570
Date Posted: May 12, 2011 at 12:08 AM
Check out Tsunami twisted cables, they are flexible and they twist lock, they also have a higher grade in nickel, I have used these for the last 5 years and its been a good brand owned by Metra.
Chadillac
Posted By: teenkertoy
Date Posted: May 12, 2011 at 1:07 AM
Stinger also makes a twisted pair cable that is well regarded and inexpensive, though the connector is fairly typical. I've been using the 6ch variety for the past year or so with no problems or noise.
-J
Malcom: "This is the captain. We have a...little problem with our engine sequence, so we may experience some slight turbulence and then...explode."
Jayne: "We're gonna explode? I don't wanna explode.
Date Posted: May 12, 2011 at 9:20 AM
Oldspark, I believe he was referring to Monster brand cables.
Posted By: gstacks
Date Posted: May 18, 2011 at 1:25 PM
I have had  a set.  The connectors were so tight it pulled the outer connections on the amp.   Millionbuy.com usually has good deals on Monster brand RCA's.  I went with their 4 channel and 2 channel set.   Never will use them again.
