factory deck, loc to sub problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=127530
Printed Date: May 14, 2026 at 10:30 AM
Topic: factory deck, loc to sub problem
Posted By: watasnake
Subject: factory deck, loc to sub problem
Date Posted: June 03, 2011 at 10:26 AM
Hello, I have a 2007 Ridgeline with Navi. I have components in the front and a sub running through a cheap Scosche line-level converter (SLC4) into a Kenwood eXcelon KAC-X4R. The components work fine but... The subwoofer does not work unless I either place the sub output to a speaker then hook it up to the line input or toggle the line input on and off. Any clue what to do? Maybe a different line converter - by the way, I tried 2 different line converters - the same model and brand
Posted By: DYohn
Date Posted: June 05, 2011 at 9:15 AM
What is your LOC connected to?  Where is it getting its signal?
Date Posted: June 06, 2011 at 9:18 AM
Right to the factory Sub out - it also works when I short the input, then everything works -
Date Posted: June 06, 2011 at 9:19 AM
I now have it connected to an Audiocontrol LC6i - same thing
Posted By: DYohn
Date Posted: June 06, 2011 at 9:32 AM
The factory sub out, eh?  Before the factory sub amplifier or after it?
Date Posted: June 06, 2011 at 11:43 AM
after the factory amp - weird.
Posted By: i am an idiot
Date Posted: June 06, 2011 at 2:25 PM
Connect only the left or right RCA cable to the amp, does it play now?
Posted By: DYohn
Date Posted: June 06, 2011 at 5:22 PM
^^^  That was my next question!  posted_image  Also, does the factory sub make any noise?
Date Posted: June 06, 2011 at 8:37 PM
I am thinking he has wired the LOC out of phase, thus producing no sound at all when both RCAs are plugged in.
Posted By: DYohn
Date Posted: June 07, 2011 at 9:49 AM
Yes, either that or there is no signal (or power) to the OEM sub amp in the first place.
