box design
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=128065
Printed Date: April 22, 2026 at 9:53 AM
Topic: box design
Posted By: pumpkinman
Subject: box design
Date Posted: July 27, 2011 at 12:53 PM
Hello all..Im looking for help on building an enclosure for 4 orion hccas.. i dont have much room in my car but it can be done..im not good at box designing.its in a 1998 chevy cavalier.If anyone could help me design a box it would be very much appreciated.. i get lost in the math..anyone willing to help please contact me thank you very much.
jl-audio13w7 2 12.2 orion hccas.. massive p1500.1 amp.. american base amp 400.1 spl.. crunch 3000 pro amp..2 jl-audio 15w4d4s subs
Posted By: jpeterman15
Date Posted: July 30, 2011 at 5:55 AM
try this.....https://www.directeddealers.com/manuals/OG/Orion/GHCCA102%202008-11MLweb2.pdf
jpeterman15
Posted By: DYohn
Date Posted: July 30, 2011 at 2:28 PM
The two most important considerations in automotive enclosure design is 1) making it fit the vehicle and 2) making it the correct size for your drivers.  Often 1) is more critical since drivers can be swapped out if you find you must use a size different from what your first choice might require.  So I recommend measuring your available space first and figure out what you CAN put into your vehicle, then if the woofers you have don't work well in that space find some that will.
