using amp wire instead of batt cable for
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=128078
Printed Date: May 16, 2026 at 5:51 PM
Topic: using amp wire instead of batt cable for
Posted By: nfrank89
Subject: using amp wire instead of batt cable for
Date Posted: July 28, 2011 at 4:09 PM
Dual battery setup? Is there any reason I shouldn't use 2 awg wire for a dual battery setup in a 1970 bronco with either battery mounted atop the rear wheel wells. Battery cable uses heavier copper strands. Amp wire is much cheaper so can I use it or not? Or should I just keep the main battery under the hood?
Posted By: i am an idiot
Date Posted: July 28, 2011 at 4:37 PM
You can use amp wire.
Posted By: nfrank89
Date Posted: July 28, 2011 at 10:22 PM
thanks!
