missing harness in 2000 tundra 2 into 1?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=128154
Printed Date: May 16, 2026 at 4:43 AM
Topic: missing harness in 2000 tundra 2 into 1?
Posted By: delray01
Subject: missing harness in 2000 tundra 2 into 1?
Date Posted: August 06, 2011 at 12:32 PM
I am putting the factory stereo back in my 2000 tundra and think I am missing a harness or something. It has been several years since I did this and my memory is fuzzy.
I have a place for the 20 pin connector on the back of my radio which goes to the factory amp which I left untouched ... no problem there. However I have two other plugs and only one plug on the back of the radio. I dont recall having a 2 into 1 harness but maybe there was one that I misplaced. Any ideas?
posted_image
posted_image
Posted By: i am an idiot
Date Posted: August 06, 2011 at 8:31 PM
If you want to use the factory amp, you will need a Metra 70-8112 or 70-8113, I will look to see which one is for the 2000 model year.  If you want to bypass the factory amp you will need a Metra 70-1761 harness.  The 8112 and the 8113 are RCA driven.  If your radio has front and rear RCA connections, all will be fine.  If it has only one set, you will need to use Y adapters and you will not be able to fade front to rear.
EDIT 70-8113 is the harness that is for the 2000 year model.
Posted By: delray01
Date Posted: August 06, 2011 at 8:34 PM
Thanks for the reply. I actually forgot that the 2 harnesses plug in to the bottom of the amp. I am back in business now.
