Wire labeled "Illumination"
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=12819
Printed Date: May 09, 2026 at 9:21 AM
Topic: Wire labeled "Illumination"
Posted By: zoomster
Subject: Wire labeled "Illumination"
Date Posted: April 27, 2003 at 7:19 PM
  Just bought an open box pioneer unit, DEHP-2500, and of course it came without any manual or diagrams.  Now, I have figured out the power, battery and speaker wiring (I think...) but on the units connector harness there is a wire labeled "Ill"  I assume this means illumination.  But where does it connect to, if at all, on my 1987 Honda CRX Si?  And if anyone knows where I can get the wiring diagram, colors and all, for this harness to the radio on the car that would be great, since the previous owner cut the standard connector off and hard wired the replacement in.
  By the way, just in case I'm wrong, feel free to tell me how this thing wires together.  This is a first time for me and even though I believe I have it figured out it would be comforting to have it confirmed by the Pros...Thanks in advance
Red and black...it's their colorscheme
Posted By: jgold47
Date Posted: April 27, 2003 at 7:26 PM
so you have no harness.....yes that orange wire is for illumination, if your crx has illumination wires, which it might? you would hook to that and when enabled on the deck it can dim the deck with the headlights....as for the wire colors, you might want to take it to best buy or something and have them wire in a reverse harness that way you wouldnt have any problems in the future.....should be like 30 for the harnesses and whatever they charge to install it!
Posted By: zoomster
Date Posted: April 27, 2003 at 7:31 PM
OK, so that wire is used to dim the deck lights when I turn the headlights on, because they assume at night the deck lighting doesn't need that much illumination...cool, that makes sense, my clock and such dim when the head lights turn on.  Excellent thanks for the help.
Posted By: jgold47
Date Posted: April 27, 2003 at 7:32 PM
posted_image
Radio 12v
posted_image
 WHITE/ blue
posted_image
posted_image
 radio
posted_image
posted_image
Radio Ground black   -  radio
Radio Ignition yellow/red   +  radio
Radio Illumination RED / black   +  radio
Factory Amp Turn-on
Power Antenna
LF Speaker +/- blu/grn - gry/blk    radio
RF Speaker +/- RED / grn - brn/blk    radio
LR Speaker +/- blu/yel - gry/wht    radio
RR Speaker +/- RED / yel - brn/wht    radio
this is for an 87 integra but the colors should be the same....you need to verify them using a multimeter but this should give you a start in the right direction...
Posted By: Velocity Motors
Date Posted: April 27, 2003 at 9:29 PM
The ILL wire is not supposed to be hooked up to the DIMMER wire on the car. The DIMMER wire will fluctuate from 12 volts down to GROUND ( or a little above ground ). If you attach the ILL of the deck to the DIMMER wire of the CRX, you will blow the ILL lead and the display will not come on after that. Most decks have an ORANGE / WHITE wire designated for the DIMMER.
Posted By: QuinnX1
Date Posted: April 27, 2003 at 9:33 PM
Hey, here's a thought just don't hook that wire up! The unit will still function properly.
