Subwoofer Box deminsions Help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=12865
Printed Date: May 08, 2026 at 6:56 PM
Topic: Subwoofer Box deminsions Help
Posted By: Allen1964
Subject: Subwoofer Box deminsions Help
Date Posted: April 28, 2003 at 3:08 PM
I recently purchased 2 10" subwoofers and am gonna build the box myself.
 Could someone please tell me the the best size box for these subwoofers?
 PoikAudio GXR104
Freq. Response-29-400Hz
Peak Power Handling-365w
Continous Power Handling-165w
I dont even know if I gave you the right info or not but let me know and I can put it in
I would also like to know how far apart to put the speakers from each other and how far from the top and bottom
I am going to put both of them in the same box of course and it will be enclosed.They will be going in the trunk of a 85 Tbird
Any info will be appreciated
Posted By: esmith69
Date Posted: April 29, 2003 at 6:52 AM
Might wanna check out these links for more info about building your own enclosures.
https://www.eatel.net/~amptech/syndicate/spboxnew2syndicate.htm
https://www.installer.com/tech/box.html
https://www.polkaudio.com/car/toolbox/subboxplans/index.php
Polk's manual for these subs recommends for each subwoofer, a sealed enclosure with 0.65 to 1.0 cu. ft. of internal volume.  Also be sure to check out the12volt's own subwoofer enclosure section.
Posted By: bberman1
Date Posted: April 29, 2003 at 4:45 PM
A sealed enclosure of 1.0 cu/ft per sub will give you optimal sound. If your going to build the enclosure your self I would build a 2 cu/ft enclosure, and put a divider down the center so each sub has its own camber with a volume of around 1.0 cu/ft. you can use the 12volts volume calculator to calculate the size of your enclosure https://www.the12volt.com/caraudio/boxcalcs.asp#rec Also be sure to use at least 5/8 or larger MDF board when fabricating the enclosure
Posted By: crroush
Date Posted: April 30, 2003 at 2:03 PM
Also keep in mind if you buy 3/4 " mdf it may not really BE 3/4", so you might need to take in account for that, because those small tolerance differences can add up quickly when assembling a box. Screw and glue is also a good idea.
Craig Roush
BSEE
