power acoustik cpt1-4000d amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129651
Printed Date: March 31, 2026 at 3:05 PM
Topic: power acoustik cpt1-4000d amp
Posted By: 18sbb
Subject: power acoustik cpt1-4000d amp
Date Posted: December 11, 2011 at 6:28 PM
Power Acoustik CPT1-4000D Amp
A month ago my amp stopped working and my battery was getting bad so I pulled out my system until I could get a new battery. The last time it was hooked up I was playing a bass test song and everything went completely out and when I looked at my battery it was sweating water bad. So I bought a yellow top the other day and installed everything back. When I start my car my amp turns on in protection mode and the car dont stay idled, it kept reving up and down. When I went to the back of the car and looked at my sub it was fully flexing out and going back in and out. I went through the steps to see what could be wrong and narrowed it down to my REM. I have everything plugged into my amp but when I touch my REM into the amp (where its supposed to go) it automaticly goes into protection mode. My REM wire is wrapped around a fuse in the fuse box that turns on when the car does. I tried three different fuses to make sure it wasnt the fuse but still nothing works. Can someone please help?
Posted By: i am an idiot
Date Posted: December 11, 2011 at 8:00 PM
It is not your remote wire.  It is you amplifier.  It is defective, for the sake of your woofer, do not turn it on again.  It NEEDS to be repaired.
Posted By: 18sbb
Date Posted: December 12, 2011 at 6:41 AM
Are you 100% positive? I mean I just dont want to pay the $50 return shipping. What is it doing? Could you explain what is going on?
Posted By: 18sbb
Date Posted: December 13, 2011 at 7:33 PM
Can anyone explain what has happened to my amp? Or if there is any way of fixing it?
Date Posted: December 13, 2011 at 8:56 PM
Have you used a volt meter to verify that the amp is getting 12 volts across the power and ground terminals of the amplifier?
