amp will not turn on
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129761
Printed Date: April 01, 2026 at 3:01 PM
Topic: amp will not turn on
Posted By: royalfam
Subject: amp will not turn on
Date Posted: December 19, 2011 at 5:56 PM
alright so I have Two 10 inch CW series massive audio subs, 600w RMS each and a p1000.1 massive audio amp. the subs are wired at 2 ohms. The system was running fine til about a week ago when the amp started going into protect when i turned the HU on, and now it wont even go into protect or turn on at all. I unplugged the speakers and RCAs leaving only the Negative and positive and remote, still does the same thing, tried it with RCAs and Speakers plugged in, same thing. when i do a jump from the 12v to remote it turns on but goes into protection. i replaced the remote wire and ground wire along with changing my ground connection spot, and it still wont turn on. I checked the fuse in the deck and that was still good. My amp doesnt have an outside fuse that i can check but I hooked my amp up too a friend of mines system, Two 12inch hifonics brutus subs and it bumped like normal, so its not my amp, my inline fuse by the battery still shows the voltage(its digital) but i cant see if its blown. Would the fuse still turn on if its blown? I have a huge feelings its my inline fuse but im not sure. and my ground and positive wires are 4 gauge, the remote is 18 or 16. I also dont have a DMM right now so thats outta the question.
Posted By: i am an idiot
Date Posted: December 19, 2011 at 7:46 PM
Without a DMM, there is not really much we can do for you. Or at least not much I can do for you.
Posted By: royalfam
Date Posted: December 19, 2011 at 8:08 PM
Looks like ill be getting one tomorrow then lol. ill post results when I can.
Posted By: soundnsecurity
Date Posted: December 20, 2011 at 4:20 PM
sounds like its the fuse, and yes the voltage display will still work if the fuse is blown depending on how the voltage display is wired. by jumping the remote to the +12v on the amp you fed the amp power from the remote wire's circuit but it still isnt enough for it to operate so it goes into protect. if your main fuse is an AGU type ( cylinder glass fuse) then it can look like its still good but be blown. if you are using an ANL type fuse then you might have a loose connection.
Posted By: birdman41
Date Posted: December 22, 2011 at 4:10 AM
Get a volt meter and probe the red positive lead on the 12v connection of the amp and ground the black lead..see if you're getting 12v. If not, there is either a loose connection between the amp and battery, or the fuse is gone. If the amp is going into protect mode, sounds like the speakers and rcas are wired wrong. It may have worked initially, but over time it will wear down the amp and shut it down.
Posted By: royalfam
Date Posted: January 03, 2012 at 12:31 AM
So i found out what it was. My ground connection was bad. i grounded it to a seat bolt the second time, which was touching metal, but behind that metal was some sort of wood or something. So after replacing every wire and fuse, i drilled a whole into the chassis and sanded it down, amp turns on, speakers work. SMH lol. Live to learn ehhh.
