new alpine gear
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=131425
Printed Date: May 16, 2026 at 12:16 PM
Topic: new alpine gear
Posted By: equilibrium1990
Subject: new alpine gear
Date Posted: May 17, 2012 at 5:53 AM
Most of you should know about this already as it's old news but if not!
https://www.alpine-usa.com/company/press/general/ 2012/alpine-introduces-12-new-subwoofers-and-unified-sub-box-program/
Eagerly awaiting this gear in AUS!!!
I was wondering if anyone had the Thiele/Small electromechanical parameters for the Alpine SWR-12D2 in particular?
Thanks :-D
Posted By: DYohn
Date Posted: May 17, 2012 at 8:30 AM
Posted By: i am an idiot
Date Posted: May 17, 2012 at 6:44 PM
Date Posted: May 17, 2012 at 7:57 PM
No I mean the SWR-12D2 Dual 2-ohm 12-inch Sub woofer
This is the NEW line not the old 600RMS 1242D the 12D2 1000RMS :-)
    CEA-2031 Speaker Specifications: 1000W RMS, 2000 Peak Power Handling
    Frequency response: 24 hertz – 200 hertz
    Mounting Depth: 6 3/8-inches
    Available: March
    MAP: $249.95
Date Posted: May 17, 2012 at 7:58 PM
EDIT: This is the NEW line not the old 600RMS 1223D the 12D2 1000RMS :-)
Date Posted: May 17, 2012 at 8:11 PM
DYohn i see that you are a moderator, Please excuse this link. It is not for pricing, Simply to verify the item I am referring to.
Remove it if it cannot be overlooked :-)
https://www.crutchfield.com/S-hsngFa8aXJp/p_500SWR12D2/Alpine-SWR-12D2.html
Date Posted: May 17, 2012 at 8:38 PM
The only thing I can find on their website as a 12D2 is the SWS that DYohn posted a link to.
Date Posted: May 17, 2012 at 9:15 PM
It's frustrating because I want to order them soon and in the 2-3weeks it takes to freight them here I could have the enclosure built :-(
Posted By: tommy...
Date Posted: May 19, 2012 at 9:34 AM
Yeah, the SWR-12D2 is new for 2012. They are releasing a few DDin units to compete with(pricepoint). They will have a $599 DDin that they refer to as "Alpines Step-Brother"... But something like 6 new DDins... The power pack has a Universal Option now. I went to the Alpine Training. They have a new 8" monitor,as well, coming out. Check out the Fuses on the new Alpine Amps.
M.E.C.P & First-Class
Posted By: DYohn
Date Posted: May 19, 2012 at 9:51 AM
On your Crutchfield link click on "see more info about this item."  They offer some of the T'S specs as well as enclosure size recommendations.  I am surprised I don't find this on the official Alpine web site, however.
Posted By: tommy...
Date Posted: May 19, 2012 at 10:39 AM
Check out the info for the new amps... 2-4 ohm load and what happens when 1ohm is introduced. They mentioned something about the enclosures across the board are similar(Cant remember exactly, will look at notes, but a type S will be the same as a type R enclosure...Hmmmmm). Also, Dont go any higher then the Type R's... Type X are a disappointment when compared to the Type R Specs... One guy at the training had just filled his car with Type X and the Rep said... "Sorry"... "At least you can pass it on to the Customer..."
Date Posted: May 20, 2012 at 2:43 AM
Sensitivity      84.7 dB at 1 watt
Frequency Response      24 - 200 Hz
RMS Power Range (Watts)      300-1000
Peak Power Handling (Watts)      3000
Top Mount Depth (inches)      6 3/8
Bottom Mount Depth (inches)      7 3/16
Cutout Diameter or Length (inches)      10 7/8
Vas (liters)      46
Fs (Hz)      27
Qts      0.44
Xmax (millimeters)      20
Overlooked that, Thanks!
sealed box volume: 0.75-1.00 cu. ft.
If anyone here was to buy these woofers would you go with manufacturer recommendations or make a custom enclosure with something like BassBox?
My current SWR-1043D's go well in .9Cu Ft each sealed, Nice Punch and ability to go low enough to flex my entire parcel shelf and steering wheel :-D Rear view mirror and side mirrors are already useless so suffice it to say they are not limited by this enclosure.
I'm Thinking 1.00 Cu Ft - 1.2 Cu Ft.
Date Posted: May 21, 2012 at 12:17 AM
Ordered a Hifonics Zeus 3000.1D today, Should see it in a week they say :-S doubting that but we'll see :-)
Date Posted: May 24, 2012 at 4:46 AM
FINALLY!!!!!!!!!!!!!!!
https://www.alpine-usa.com/product/view/swr-12d4/
