speaker vs amp power
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=131596
Printed Date: March 29, 2026 at 12:19 AM
Topic: speaker vs amp power
Posted By: alajoe
Subject: speaker vs amp power
Date Posted: June 12, 2012 at 6:48 PM
In my last car (2002 Escape) I had an MTX thunder form box. In it was a Single thunder 4500 12" sub rated for 225 watts. This would be about a $75 sub new. I was driving this with an alpine 140 watt mono amp. I was more than pleased with the amount of bass this set up produced but I understand this was a relatively minimalistic system.
I buy most of my stuff used off of Craig's list so I can not always get exactly what I want so I was wondering what would happen if I took the exact same amp and hooked it to a sub that would cost $300-400 new and was rated for say 1000 watts? Would it sound better because I have a much more capable sub or would it sound worse because I would be so under driving the sub.
Lets look also at say 5.25 speakers and compare say Alpine type s and type R. The s's are $60 a pair and rated for 55 watts. The R's are $120 a pair and rated for 90 watts. If you drive these with a 40 watt amp which should sound better?
Posted By: DYohn
Date Posted: June 14, 2012 at 8:28 AM
In general, amplifier power has nothing (or very little) to do with how speakers sound.  Better speakers sound better regardless of the amplifier.  In the case of your Alpine example, the type S will sound like Type S and the Type R will sound like Type R no matter what amp you use.  Buy the speakers you like the most.
Posted By: soundnsecurity
Date Posted: June 14, 2012 at 1:03 PM
you will get better results by making sure the sub and the box are compatible with each other. if you plan on using the tunderform box and just installing a different sub then you could get better or worse results than you already have depending on if the sub and box play nice with each other.
