which 4 channel amp?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=131675
Printed Date: March 29, 2026 at 11:46 PM
Topic: which 4 channel amp?
Posted By: deeryders
Subject: which 4 channel amp?
Date Posted: June 22, 2012 at 12:50 PM
I have 6 Whip Audio 6.5 speakers which are 100 watts RMS along with 2 soundstream TWS.4 tweeters. The amp I have not is a logic DBx1004. It plays very very well. Except the impendance is to high for the amp therefore it over heats from time to time. Someone had suggested a Rockford T600-4. You think it is worth it or should I just put fans underneath what I have. Also, what is the difference here:
https://ceramic.audiogoshop.com/rockford-fosgate-power-t6004-600-watt-multi-channel-amplifier-electronics_p6629.html?offer_id=B000NJFUWG
https://www.crutchfield.com/p_575T6004P/Rockford-Fosgate-Power-T600-4-Standard.html
------------- MECP Certified
Dont Ground Out!!!
Posted By: i am an idiot
Date Posted: June 22, 2012 at 3:58 PM
If properly connected, that amp should run all of those speakers without any problems. How many speakers do you have connected to each channel of the amp?
