wiring cooling fans for two amplifiers
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=131864
Printed Date: May 14, 2026 at 1:56 AM
Topic: wiring cooling fans for two amplifiers
Posted By: fuzzy01
Subject: wiring cooling fans for two amplifiers
Date Posted: July 21, 2012 at 10:07 PM
Hi,I have a Logisys 6 channel fan controller that I want to install to control 3 cooling fans. The fans are rated at 0.950A and I want to be able to run them while the amplifiers are on, and while they are off if need be. Does anyone know if there is a site that shows the proper way to wire them? Any info would be a great help. Thank you.
Posted By: DYohn
Date Posted: July 22, 2012 at 10:23 AM
Is this a car audio product?  Did it come with an owner's manual?
Posted By: fuzzy01
Date Posted: July 22, 2012 at 11:56 AM
Hi,the Logisys is a 6 channel fan controller that is a 5.25" bay device,it came from Newegg.The fans are Mechatronics that came from Parts Express.There was no owner's manual included in the box.Thank you.
Posted By: DYohn
Date Posted: July 22, 2012 at 1:02 PM
So it's a part for a computer?  If it operates off of 12 volt DC you might be able to make it work in a vehicle if you know the power requirements and the pin-out.  But it would definitely be a custom rig job, and not something you should take on if you don't know what you're doing.
Posted By: oldspark
Date Posted: July 22, 2012 at 11:36 PM
The fans should handle car voltages.
And you just need to power them from the amplifier's ON switch.
There is no point continuing the cooling once the amp is turned off. (The heatsinks may get hotter, but the bits being cooled (ie, semiconductor junctions) are definitely cooling.)
