2000 Buick Century radio wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=13225
Printed Date: May 07, 2026 at 5:36 AM
Topic: 2000 Buick Century radio wiring
Posted By: Leszkoaudi
Subject: 2000 Buick Century radio wiring
Date Posted: May 06, 2003 at 9:07 AM
Had my radio recently stolen. Wires all cut.
Problem with splicing in new radio harness (scothe)
there are three (3) orange wires,three dark green wires,3 gray wires.
no red wire.
anyone seen this before?
thanks....any info would be greatly appreciated.
Posted By: bberman1
Date Posted: May 06, 2003 at 9:59 AM
First of I believe that car has a class 2 data bus system https://www.velocitymotorsport.com/install_notes/OBDII.htm which means that it dose not have a switched+ 12 volt ( red wire) .now In order to get a switched + 12 volt you will need to tap into the pink wire located in the ignition wiring harness. But before we go any further can you tell me if the door chime still works? Also I take it you are installing an aftermarket head unit?
Date Posted: May 06, 2003 at 10:43 AM
Door chime is operational. Key in ignition, and door open = chime.
I am trying to install a OE buick radio,same dimentions as the one stolen.
I an using a GM03R reverse car stereo connector.
Wiring is as follows:3 Yellow,1 Orange,1 Dark Blue,2 grey,1dark grey,1Black\white stripe,1 light blue,1 tan,3 dark green,1 light green. 15 wires all together.
