hi voltage pre-outs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=13262
Printed Date: May 07, 2026 at 5:29 PM
Topic: hi voltage pre-outs
Posted By: greenbroncoguy
Subject: hi voltage pre-outs
Date Posted: May 07, 2003 at 5:50 AM
is there a limit on the imput voltage on some amps as to how high the power can be on the inputs for the RCA jacks? I have seen some headunits with output power as much as 5v and i was wondering is it safe to use this on any amp?
Posted By: dohcser
Date Posted: May 07, 2003 at 6:53 AM
Yes you need to check the specs on the amp! It is known as input sensitivity, some amps cannot accept a high voltage input. Definately want to check the specs.
Posted By: wvsquirrel
Date Posted: May 07, 2003 at 7:48 AM
If you already have the amp and headunit, you can buy an aftermarket gain gontroller like this one from Rockford that will allow you to adjust the voltage level going to the amp. I'm not endorsing RF, I just threw it out there because I've seen that particular one used before to solve this type of problem.
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
Posted By: Big Purds
Date Posted: May 07, 2003 at 9:53 AM
some amps can accept beyond 16V for input, some as little as 3V...some even less than that...you can blow the input stage by over loading it if you put too much power into it...
