making a new 8 pin din cable
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=133374
Printed Date: May 14, 2026 at 8:04 PM
Topic: making a new 8 pin din cable
Posted By: siksemper
Subject: making a new 8 pin din cable
Date Posted: January 20, 2013 at 11:32 PM
Hello, I am trying to hook a second subwoofer to my a/d/s ph15 amplifier with a 642Csi a/d/s crossover and I've been told I need to modify the DIN cable to do so. Channel 5 and 6 are for subwoofers but i want to bridge channel 5 and 6 for 100 watts rms and also bridge channels 3 and 4 at 100 watts rms. So basically I need to make a din cable that takes the signal from channel 5 and 6 and splits it allowing it to be used on channel 3 and 4 so that i have 2 bridged channels running my subwooffers. So what are my options and what all do I need to do such a thing? Here is a diagram of the original DIN layout on the amp:
posted_image
So what are my options here? thanks
Posted By: Ween
Date Posted: January 21, 2013 at 11:30 PM
make your own adapter cable with male and female din connectors. rewire the din connector inside the amplifier to suit your needs.
Date Posted: January 22, 2013 at 12:16 AM
Okay that's what i thought, I just have to make a jumper wire basically? I shouldnt need to worry about extra grounding or anything right?
Posted By: i am an idiot
Date Posted: January 22, 2013 at 4:44 AM
Use 2 RCA Y adapters.
