damaged premium sound amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=133603
Printed Date: May 15, 2026 at 3:31 AM
Topic: damaged premium sound amp
Posted By: marlon stjulien
Subject: damaged premium sound amp
Date Posted: February 15, 2013 at 5:02 PM
I have 2006 Chrysler 300 with no sound. Premium sound amp is damaged. Can I bypass or what should I do
Saint
Posted By: soundnsecurity
Date Posted: February 15, 2013 at 8:42 PM
if you still have a totally factory system then no you cant bypass the factory amp. the factory radio will only provide a signal source without any real power, not only that but the volume control is designed to only turn the amp up with a data signal, which means that you cant even use a line output converter on the factory radio if you were planning on just replacing the amp with an aftermarket one.
honestly, the cheapest option i think you have would be to replace the factory radio, if you havent already, and run all new speaker wire to each speaker. you should still use the factory integration harness so that you can keep the CAN data loop intact for diagnostic purposes and to save yourself the task of running a wire to ignition to turn on the aftermarket radio.
the only real problem you would run into by doing this is because there will be more speakers than your radio will support, i believe the 300 has 3 speakers on the dash, left, right and center. it might take some creativity to make them play correctly because they definitely dont play a full range audio signal, they are filtered by the factory amp so that they play only what they are designed to play. making those speakers play correctly will require another amplifier and maybe an outboard crossover.
with all of those extra's in mind, you might be better off either re-wiring the whole system to an aftermarket setup or maybe even just replacing the factory amp. i know the factory amp might be expensive but with the amount of work involved with converting the system to aftermarket it still might be your cheapest route
Posted By: racerjames76
Date Posted: February 16, 2013 at 8:51 AM
I agree with s&s that replacing the factory amp may be the cheapest short term option, but the problem is that the factory parts will never be built with the same quality you can get aftermarket. Now there are plenty of aftermarket parts made even more cheaply than stock parts. Do research, shop around and you can get high quality aftermarket stuff for a decent price.
Keep in mind that the stock amp went out for a reason. That reason may still exist even with a new factory amp, and can eventually burn out that one too.
I feel it is always a better investment to upgrade to quality aftermarket equipment than to invest in the same old stock stuff. If the stock amp lasted 5 years are you even going to be able to buy that same old stock stuff in another 5 years? Do the work for the aftermarket stuff and you will also make it easier to change out in the future should the need/want arrise.
Stock equipment - easier and cheaper short term
Aftermarket equipment - more difficult and more expensive up front, but future proof's your vehicle a little, and usually ends up sounding better.
I always caution people in this scenario that aftermarket speakers are designed to be part of an aftermarket system, so it may not have the bass response you expect from the current system! posted_image
Just my $0.02
To master and control electricity is perfection. *evil laugh*
Posted By: scoobyxj
Date Posted: February 19, 2013 at 8:14 PM
You can also go to the junk yard and find a factory replacement. FWIW there are probably more than one Chrysler vehicle that used that amp and they could probably cross reference and find you what you need.
