four channel amp one sub two speakers.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=133920
Printed Date: May 15, 2026 at 1:52 AM
Topic: four channel amp one sub two speakers.
Posted By: starfox5194
Subject: four channel amp one sub two speakers.
Date Posted: March 24, 2013 at 3:53 PM
Alpine MRV F450 70x4@4ohms 100x4@2ohms.
2x Jensen 6.5" 40RMS 4ohms 125 peak.
Sony xplod 300RMS 10" 4ohm SVC Sub.
DUAL XHD 7714 Head unit.
What is the best way to wire this all up?
Should I do speaker level inputs or use RCA cables?
I want to take channels 3+4 on the amp and wire them to work with the sub. I don't know if that's possible. Maybe it can only be done with one channel.
The first two channels I want going to the 6.5" speakers.
I know the sub won't hit hard at all with 70RMS. I just want to add a little bass to the music.
Thanks guys.
Posted By: i am an idiot
Date Posted: March 25, 2013 at 1:19 AM
You can bridge the sub on channels 3/4. The amp will provide 200 watts to the sub.
I would use RCA cables.
Date Posted: March 25, 2013 at 10:23 AM
sounds perfect thanks!
