troubleshooting audio loss
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=134662
Printed Date: May 16, 2026 at 11:40 AM
Topic: troubleshooting audio loss
Posted By: austinjasonxxx
Subject: troubleshooting audio loss
Date Posted: August 04, 2013 at 12:07 PM
I was driving from the house this morning and sub stopped playing. Stopped and checked all connection, everything secure. Got back home checked amp. Has power, rca's are secure, power ground and remote secure. No protection light on. Checked sub wiring with multimeter, read correct impedance. My only guess is that for some reason the rca's on the back of the head unit are the problem. Any suggestions ?
I should mention that the interior speakers didn't quit just the sub.
Posted By: oldspark
Date Posted: August 04, 2013 at 5:41 PM
The amp's fuse(s)?
Date Posted: August 05, 2013 at 6:48 AM
All the fuses are good.
Posted By: DYohn
Date Posted: August 05, 2013 at 9:33 AM
Disconnect and check the resistance of the subwoofer voice coils. ------------- Support the12volt.com
Date Posted: August 05, 2013 at 10:30 AM
2 ohms.
Posted By: DYohn
Date Posted: August 05, 2013 at 10:36 AM
OK, so sounds like the speakers are likely still good. Could be your amp just died. Take it to a car audio shop and ask them to test it. Or you can do a rough test yourself to see if it's working. Disconnect the woofer, set the meter to AC Volts and connect across the speaker output terminals. Play some material. What's the output voltage? ------------- Support the12volt.com
Date Posted: August 05, 2013 at 10:59 AM
.015-.026
Posted By: DYohn
Date Posted: August 05, 2013 at 12:14 PM
austinjasonxxx wrote:
.015-.026
Volts? Assuming the system was on, either the amp is toast or it is receiving no input. ------------- Support the12volt.com
Date Posted: August 05, 2013 at 12:31 PM
Yes it was on and measured in ac volts. My original thought was for some reason the rca's came unhooked from the head unit. They should have about 4-5 volts running through th correct. So if I checked them at the amp end I should show voltage if they are indeed connected.
Posted By: DYohn
Date Posted: August 05, 2013 at 2:33 PM
Yes, chack for all proper connections before you do anything. The RCA should have between 0.25 and 5 AC volts, depending on the volume level. It is possible the head unit subwoofer output has quit (or gotten turned off, which I assume you checked?) ------------- Support the12volt.com
Date Posted: August 05, 2013 at 4:18 PM
Yes sub output is turned on. Taking the kidos to the fair so if I have time tonight I will check if not tomorrow morning. thank you for your help today. I will tell you what I find out.
Posted By: i am an idiot
Date Posted: August 05, 2013 at 10:32 PM
If you have an AGU fuse ANYWHERE in the path of the power wire, change it. Even if it LOOKS good.
