sub choice
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=134738
Printed Date: May 16, 2026 at 10:41 AM
Topic: sub choice
Posted By: 78 lemans
Subject: sub choice
Date Posted: August 15, 2013 at 10:47 PM
First off this is for my second (spare) car so its kind of a piece together system. Its in a 99 Dodge Avenger, basically a mitsu eclipse.
I will be powering the mids and highs with an Mtx RFL404 50x4 @ 4 ohm, 100 x 4 @ 2 ohm. Rear is a pair of 6x9 soundstream 100w rms 3ways, front im undecided wether to use a set of 6" 2 way mtx that I have or pick up a set of components as it currently has stock door and dash speakers. Leaning towards components.
For sub amp the one I currently have in it is a Planet Audio rxd1000
400x1 @ 4ohm rms
750x1 @ 2ohm rms
1000x1 @ 1ohm rms
Its currently powering a single 4ohm Audiobahn 400w rms 10" in a sealed prefab box. I want more out of it. I found a deal on a 15" Kicker solobaric L7 dual 2ohm in a box that sounds good with his current set up at 1ohm, but would I be better off spliting the 1000w into two 10 or 12's at 1ohm or even splitting the 750@2ohm or is the one 15" a good choice?
I listen to a mix of rock, metal, hiphop/rap, some country but not much, etc. I like clean bass but do like to push it sometimes as well.
Also the sub will be in the trunk with the seats up most of the time.
Posted By: DYohn
Date Posted: August 16, 2013 at 10:23 AM
Any Kicker is going to sound much batter than any Audiobahn no matter what you do. Go for the single 15. ------------- Support the12volt.com
Date Posted: August 16, 2013 at 12:09 PM
I am replacing the Audiobahn either way. But would two tens or twelves sound better or louder than the one 15" powered by the same amp?
Posted By: avanthika
Date Posted: September 16, 2013 at 6:22 AM
Great sharing.
