thoughts for my subs/enclosure.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=134842
Printed Date: May 16, 2026 at 4:43 PM
Topic: thoughts for my subs/enclosure.
Posted By: omniphillips
Subject: thoughts for my subs/enclosure.
Date Posted: September 07, 2013 at 12:45 AM
I purchased this amp, which is an 800 watt RMS at 1-ohm stable mono. Pioneer
I also purchased two of these subs, they claim to be DVC 4-ohm but if you look at the pictures they do not actually have two places to wire from they only have one positive and one negative with a switch for 2-ohm and 8-ohm, They are 100-400watt RMS.
Kicker
My first question is what would be the proper way to wire these particular subs to get them both at 1-ohm from the amp.
Do I treat them as 2 SVC 2-ohm subs for wiring purposes? such as this?
Wiring
Next is the enclosure, I have 3/4" MDF that I'm planning on building my sealed enclosure out of. I want to build an L-shaped enclosure behind my center console onto my back seat, as either an arm rest or if I need more internal volume a dividing wall between rear seats. I have a 2001 Toyota Tacoma double cab I should mention. Here is a forum link to what I have in mind but I want to do two subs he only has the one.
Tacoma
So as far as this goes, Which would be the optimal facing direction for both the subs in this type of enclosure and should I put a divider in between them on the inside of the enclosure.
Date Posted: September 07, 2013 at 12:50 AM
I don't think the links worked so here they are, sorry.
Amp:
https://www.crutchfield.com/p_130GMD8601/Pioneer-GM-D8601.html?showAll=N&search=GM-D8601&skipvs=T
Subs:
https://www.crutchfield.com/p_20640CWR84/Kicker-40CWR84.html?showAll=N&search=40CWR84&skipvs=T
Wiring diagram: https://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2-SVC-2-ohm-mono-low-imp.jpg
Sub enclosure idea:
https://www.tacomaworld.com/forum/1st-gen-tacomas/145374-boredom-jigsaw-one-afternoon.html
Posted By: overworked
Date Posted: September 07, 2013 at 5:48 PM
I think it's safe to say that it really doesn't matter. At least standing waves won't be an issue!
You will never achieve fantastic sound quality out of it, but you will definetly get what your after... Just get as much space as the subs require and you will be ok.
What do I personally think? It looks like my ass! But I don't have to drive it and it's certainly your easiest option, so may as well go for it.
Date Posted: September 08, 2013 at 2:38 AM
Thanks for the reply, I guess...
I'm trying to do this right the first time so if anyone else has any input it would be greatly appreciated.
Posted By: DYohn
Date Posted: September 08, 2013 at 8:53 AM
Yes, you set the DVC switch to 2-ohms and wire the subs in parallel for a 1-ohm net load. As to your enclosure, as long as the internal volume is correct (or within 10%) the shape does not matter. Mount the drivers where they fit and so that they are facing into the cabin.
Date Posted: September 08, 2013 at 1:17 PM
Thank you very much for the helpful reply. Building it today, we'll see how it turns out.
