i need box plans for 2 10z 1.4cu ft each
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=135942
Printed Date: May 15, 2026 at 8:37 AM
Topic: i need box plans for 2 10z 1.4cu ft each
Posted By: dustin arnold
Subject: i need box plans for 2 10z 1.4cu ft each
Date Posted: January 28, 2014 at 8:43 PM
if anyone has blueprints for a dual 10 inch ported box around 1.4 ft each i would buy them. i got 2 type x 10z in a ported 1.1 cu ft box now and they beat. but they call for 1.4 ported and i would love to try and build one
Posted By: tonanzith
Date Posted: January 28, 2014 at 10:32 PM
What are you putting the box in? Car? Truck? SUV?
Gary Sather
Date Posted: January 29, 2014 at 3:45 AM
its for a 98 lincoln mark viii
Date Posted: January 29, 2014 at 5:39 AM
im using jvc av71bt, alpine 3218 eq with a ppi s2000.1 and 2 dvc 4 ohm alpine type x 10z @ 1 ohm for bass. alpine mrp-f600 hertz 5x7 and 4" in front doors and hertz 6x9z in back panels with hertz tweets i put into dash and have 2 4 inch holes cut into back deck with grills covering them and i cut holes in deck to help trunk breathe so i can redo it if theres a better way to port it i just put holes that size bc they were easy and didnt require cutting of metal and were uniform.
Posted By: soundnsecurity
Date Posted: January 29, 2014 at 12:38 PM
well what you are trying to do is a real gamble, because you dont know all of the design specs of the box you are using right now. just because a sub recommends a certain airspace doesnt mean that those are the best/loudest box specs. there are way way more calculations that go into designing a box other than just the raw airspace. if you build a new box without knowing the full specs then it is just as likely that you will lose bass.
Date Posted: January 29, 2014 at 2:27 PM
well you from la i got em in a dp-10 fox box it says 1.1 each and they slam i never thought about getting something different from 1st bass note they made and thats scary. fox is a saint to me and idk y im thinking i can get better but thats y im asking you i guess its like shopping for a replacment for drew brees it dont make sense but im hardheaded and dumb and i believe theres someone who can beat a fox box and i got perfect car its so sealed and acoustically flawless
