System tuning help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=13622
Printed Date: May 12, 2026 at 9:09 PM
Topic: System tuning help
Posted By: donkason
Subject: System tuning help
Date Posted: May 16, 2003 at 9:52 PM
My head unit is a kdc-x559 kenwood, my amps are a soundstream lil' wonder and a rubicon class a 10.2, my subs are 3 JL audio 12 w3's in a open chamber 3 cubic foot box sealed. I just installed my new rubicon amp tonight and realized that it didn't have a crossover built into the amp, oops. I have one built into my head unit which has a non fading output that is the one I am running to my rubicon. It is set at 50hz. Is this a good choice for a crossover or should I leave the setting on the head unit alone and buy a seperate crossover to run in line with my rca wires. Also what would be the optimal settings for my subs. I know that how a speaker acts does vary from box to box. Any suggestions on how to tune it would be welcome.
J. Mike Perkins
Posted By: tdsteele
Date Posted: May 16, 2003 at 10:12 PM
50 hz seems low to me, i've always kept mine at between 80-100hz. I've never used a decks crossovers before so i cant say on that one.
Posted By: Spectre
Date Posted: May 17, 2003 at 1:07 PM
I suggest that if your head-unit has a 80hz crossover you use that setting, if it doesn't.......  you may want to consider a add-on crossover or pre-amp eq to control the subs seperatly from the rest of the speakers.
50hz won't hurt the subs but  your not using the 50-80hz range.
The Angel Of Death Has You!
Spectres Own The Night!
