Weird Problem with Head Unit
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=14305
Printed Date: May 01, 2026 at 7:41 PM
Topic: Weird Problem with Head Unit
Posted By: Sebastian018
Subject: Weird Problem with Head Unit
Date Posted: June 01, 2003 at 6:21 PM
Hi, I have a Pioneer Premier DEH-P850MP and it work great but today The Temperature in MIami was 110F around 1:30pm , Really Hot, and i was driving and i was hearing the radio but when I looked at the radio the screen was like when the radio is off, Black screen like if there was no power for the two screem, I stopped and I took out the faceplate and I put it back and I works great, Could be the problem because it was too hot inside of the car or probable there is something wrong with the radio? what do you guys think? thank you.
Posted By: esmith69
Date Posted: June 01, 2003 at 6:44 PM
When the display went blank, did you continue to hear sound? Or did that die too? ------------- Ethan
Donate to the12volt.com
Date Posted: June 01, 2003 at 7:00 PM
Continue to hear Sound/
Posted By: speedwayaudio1
Date Posted: June 01, 2003 at 10:00 PM
Is it a lcd disp or the organic? the heat I think was the trouble.
------------- Big Dave
Posted By: snazz
Date Posted: June 01, 2003 at 10:45 PM
i ahve had problems liek this before, only in the really cold. I know a friend who has a similar deck and if the temperature varies out of a specific range, the screen wont work. his sound doesnt work at this time. Just thought id throw that in.
------------- sometimes its not enough to do your best, sometimes you have to do what is required of you..
Date Posted: June 02, 2003 at 8:03 AM
Both the LCD and the Organic
