Box Depth for Speaker?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=144098
Printed Date: May 12, 2026 at 10:43 PM
Topic: Box Depth for Speaker?
Posted By: fathershelper
Subject: Box Depth for Speaker?
Date Posted: January 31, 2018 at 10:31 AM
Hello, ive built a ported box. One thing i overlooked was the mounting depth. The slot port runs along the back wall. The speaker barely fits. The magnet may actually be touching the port wall. I was wondering if anyone knows if this is going to be a problem. It sounds good but i only tested it a little. I the sub is vented through the magnet and the baffle is at an angle so if the magnet is touching it would be angled and only touching at the very top. I cant find any info on speaker installation as far as how close it can be to the back wall of an enclosure?
------------- Whats that noise?
Posted By: series vii
Date Posted: February 01, 2018 at 8:24 PM
You don't want the magnet against the wood be either the rear wall, port etc...
Since the woofer is vented out the bottom of the magnet, I would leave min 1" clearance, more won't hurt.
