Wiring an Amp Differently
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=144456
Printed Date: May 14, 2026 at 3:01 AM
Topic: Wiring an Amp Differently
Posted By: savagetusk
Subject: Wiring an Amp Differently
Date Posted: May 17, 2018 at 4:59 PM
I have a question about wiring in a different formation. Would it work to wire 1 channel to both the 3 " in mono and 3 channels to the 6.5" in mono? Concerned that the 3" might receive too much power from the amp.
I've never done that before. If not, what would be a good hookup for this? Thanks for the advice!
I have
(2) Poly-Planar 3-Inch Frequency Response: 70Hz to 20KHz (Single cone) SPL: 83dB Peak Power: 60W per speaker Continuous Power: 30W RMS/speaker Speaker Impedance: 4 OHMS
AND
(2) Krypt 6.5" HLCD speakers Model Krypt 6.5” HLCD Nominal Diameter 6.5 inch Nominal Impedance 4 ohm RMS Power 150 Watts Peak Power 300 Watts
Posted By: eguru
Date Posted: May 17, 2018 at 6:00 PM
Can you draw out your proposed connections. The post is not clear enough for a response.
Posted By: i am an idiot
Date Posted: May 17, 2018 at 8:14 PM
"In Mono" defeats any chance of stereo separation.
Date Posted: May 17, 2018 at 10:11 PM
I guess it would help if you knew the amp, sorry bout that. It's a BOSS Audio MC900B 500 Watt, 4 Channel. I'll draw up a diagram of how I'm envisioning it. This is on a jetski so stereo doesn't matter much.
Date Posted: May 18, 2018 at 12:33 AM
Here is a diagram that I am pondering. This is purely my thinking that it will. Keep the 3" safe and give more power to the 6.5" HLCD's
Posted By: cpalmer
Date Posted: May 18, 2018 at 7:28 AM
Just wire it standard 1 channel per speaker, then turn the gains down on the set ( front or rear ) that you've used for your smaller speakers. KISS ( keep it simple )
Posted By: DYohn
Date Posted: May 19, 2018 at 8:33 AM
Do not wire as in that diagram unless you wish to fry the amp. ------------- Support the12volt.com
Date Posted: May 19, 2018 at 9:50 AM
Thank you for the reply.
